Modeling
Modeling
polovroemen
Modeling
polovroemen
I am trying to model an F-16. I am a self taught modeler so I am nothing close to what most people can do. The problem is I can't get the complex shapes right. I also can't get the nose of the plane right.
Accepted solutions (3)
SaeedHamza
You should be more specific about your problem my frined 🙂
If the nose is what you want to model, then attach a picture of it and we will make you a screencast about it
Regards
Saeed
Saeed Hamza
You might check into the "attach canvas" command under the insert menu button.
There's a few videos on how to calibrate this and also there's information  about it on this forum.
Basically it'll give you a picture that you can trace out with sculpting tool or sketch commands.
There's lots of pictures online you can use as reference.
cekuhnen
@polovroemen
Welcome to the world of modeling - Fusion can easily build the F-16 plane if you use a proper workflow.
The air intake and how it blends into the body can be tricky but otherwise all should be easy peasy when you show
screenshots of your work or attach your fusion files so we can check it to see where you have issues 😉
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
