Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Updating Extrude when Sketch changes
3 REPLIES 3
zoe.ophelia.hammer
506 Views, 3 Replies
zoe.ophelia.hammer
I'm trying to write a script that speeds up the process of making keyboard keycaps with legends sunk into the top.
I found another script on this forum that worked similarly and i modified it to loop through a list of characters, each time updating the sketch that the extrude was based on, and then exporting the object as an STL.
The script successfully iterates through the list, changes the text field, and exports the file with the correct name, however each file that it exports has the same letter extruded into the part.
It appears that the extrude feature is not updating after the sketch updates. I found some suggestions on the forums reccomending i roll back the timeline and back to the end to get it to update, but that didnt work.
the extrude feature displays an error: "1 Reference  Failure. Cannot complete extrusion"
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        # Get the sketch named "ChangeText"
        sk = rootComp.sketches.itemByName('ChangeText')
        # Get the first sketch text.
        skText = sk.sketchTexts.item(0)
        alphabet = ["A","B","C","D","E","F","G",'H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z']
# Grab the sketch and first text entity
        for i in alphabet:
            # Change the text.
            legend = i
            skText.text = legend
            # Write in the path to the folder where you want to save STL‘s
            folder = r"X:\53.00 - 3d Printing\53.30 - Custom Models\Keycaps\Set 1.5\\"
            # Construct the output filename. Name will be the same as you‘ve changed    the text into.
            filename = folder + skText.text + '.stl'
            # Save the file as STL.
            exportMgr = adsk.fusion.ExportManager.cast(design.exportManager)
            stlOptions = exportMgr.createSTLExportOptions(rootComp)
            stlOptions.meshRefinement = adsk.fusion.MeshRefinementSettings.MeshRefinementMedium
            stlOptions.filename = filename
            exportMgr.execute(stlOptions)
            timeline = design.timeline
            adsk.doEvents()
            returnValue = timeline.moveToPreviousStep()
            adsk.doEvents()
            adsk.doEvents()
            returnValue = timeline.moveToEnd()
            adsk.doEvents()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def run(context):
    ui = None
    try:
        for i in alphabet:
            # Change the text.
            legend = i
            adsk.doEvents()
            adsk.doEvents()
            adsk.doEvents()
            adsk.doEvents()
    except:
        if ui:
3 REPLIES 3
JeromeBriot
Try the script below. You have to delete the existing extrusion of the text before running the script.
import os
def run(context):
    ui = None
    try:
        folder = r"X:\53.00 - 3d Printing\53.30 - Custom Models\Keycaps\Set 1.5"
        distance = adsk.core.ValueInput.createByReal(4)
        extrudeFeatures = rootComp.features.extrudeFeatures
        extrude = None
        for i in alphabet:
            skText.text = i
            if extrude:
                extrude.deleteMe()
            extrudeInput = extrudeFeatures.createInput(skText, adsk.fusion.FeatureOperations.CutFeatureOperation)
            extent_distance = adsk.fusion.DistanceExtentDefinition.create(distance)
            extrudeInput.setOneSideExtent(extent_distance, adsk.fusion.ExtentDirections.NegativeExtentDirection)
            extrude = extrudeFeatures.add(extrudeInput)
            filename = os.path.join(folder, skText.text + '.stl')
            adsk.doEvents()
    except:
        if ui:
import os
def run(context):
    ui = None
    try:
        extrude = None
        for i in alphabet:
            skText.text = i
            if extrude:
                extrude.deleteMe()
            adsk.doEvents()
    except:
        if ui:
zoe.ophelia.hammer
Thank you! I'll give it a try that way too.
i ended up figuring this out myself a different way. i moved the timeline moving features around and it worked.
now what this one does is moves the timeline to before the extrude before it changes the text, and then moves it back to the end afterwards.
def run(context):
    ui = None
    try:
        alphabet = ["A","B","C","D","E","F","G",'H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z', "( {\n[ <", ") }\n] >", ", ."]
        for i in alphabet:
            # Change the text.
            legend = i
            adsk.doEvents()
            adsk.doEvents()
            folder = "C:\\Users\\Zoe\\Desktop\\Keycaps\\set 1.5"
            filename = folder + "\\" + skText.text + '.stl'
    except:
        if ui:
def run(context):
    ui = None
    try:
        for i in alphabet:
            # Change the text.
            legend = i
            adsk.doEvents()
            adsk.doEvents()
    except:
        if ui:
JeromeBriot
I think that it is safer to roll the timeline back to a specific feature rather than counting how many steps to move the timeline marker.
Rename the letter extrusion as textExtrusion by right clicking on it in the timeline then run the script below:
import os
def run(context):
    ui = None
    try:
        folder = r"C:\Users\Zoe\Desktop\Keycaps\set 1.5"
        extrudes = rootComp.features.extrudeFeatures
        for txt in alphabet:
            textExtrusion = extrudes.itemByName('textExtrusion')
            textExtrusion.timelineObject.rollTo(True)
            # Change the text.
            skText.text = txt
            adsk.doEvents()
            filename = os.path.join(folder, txt + '.stl')
    except:
        if ui:
import os
def run(context):
    ui = None
    try:
            # Change the text.
            skText.text = txt
            adsk.doEvents()
    except:
        if ui:
