I'm trying to write a script that speeds up the process of making keyboard keycaps with legends sunk into the top.
I found another script on this forum that worked similarly and i modified it to loop through a list of characters, each time updating the sketch that the extrude was based on, and then exporting the object as an STL.
The script successfully iterates through the list, changes the text field, and exports the file with the correct name, however each file that it exports has the same letter extruded into the part.
It appears that the extrude feature is not updating after the sketch updates. I found some suggestions on the forums reccomending i roll back the timeline and back to the end to get it to update, but that didnt work.
the extrude feature displays an error: "1 Reference Failure. Cannot complete extrusion"
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
design = app.activeProduct
rootComp = design.rootComponent
# Get the sketch named "ChangeText"
sk = rootComp.sketches.itemByName('ChangeText')
# Get the first sketch text.
skText = sk.sketchTexts.item(0)
alphabet = ["A","B","C","D","E","F","G",'H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z']
# Grab the sketch and first text entity
for i in alphabet:
# Change the text.
legend = i
skText.text = legend
# Write in the path to the folder where you want to save STL‘s
folder = r"X:\53.00 - 3d Printing\53.30 - Custom Models\Keycaps\Set 1.5\\"
# Construct the output filename. Name will be the same as you‘ve changed the text into.
filename = folder + skText.text + '.stl'
# Save the file as STL.
exportMgr = adsk.fusion.ExportManager.cast(design.exportManager)
stlOptions = exportMgr.createSTLExportOptions(rootComp)
stlOptions.meshRefinement = adsk.fusion.MeshRefinementSettings.MeshRefinementMedium
stlOptions.filename = filename
exportMgr.execute(stlOptions)
timeline = design.timeline
adsk.doEvents()
returnValue = timeline.moveToPreviousStep()
adsk.doEvents()
adsk.doEvents()
returnValue = timeline.moveToEnd()
adsk.doEvents()
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def run(context):
ui = None
try:
for i in alphabet:
# Change the text.
legend = i
adsk.doEvents()
adsk.doEvents()
adsk.doEvents()
adsk.doEvents()
except:
if ui:
Solved by JeromeBriot. Go to Solution.
Try the script below. You have to delete the existing extrusion of the text before running the script.
import os
def run(context):
ui = None
try:
folder = r"X:\53.00 - 3d Printing\53.30 - Custom Models\Keycaps\Set 1.5"
distance = adsk.core.ValueInput.createByReal(4)
extrudeFeatures = rootComp.features.extrudeFeatures
extrude = None
for i in alphabet:
skText.text = i
if extrude:
extrude.deleteMe()
extrudeInput = extrudeFeatures.createInput(skText, adsk.fusion.FeatureOperations.CutFeatureOperation)
extent_distance = adsk.fusion.DistanceExtentDefinition.create(distance)
extrudeInput.setOneSideExtent(extent_distance, adsk.fusion.ExtentDirections.NegativeExtentDirection)
extrude = extrudeFeatures.add(extrudeInput)
filename = os.path.join(folder, skText.text + '.stl')
adsk.doEvents()
except:
if ui:
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
import os
def run(context):
ui = None
try:
extrude = None
for i in alphabet:
skText.text = i
if extrude:
extrude.deleteMe()
adsk.doEvents()
except:
if ui:
Thank you! I'll give it a try that way too.
i ended up figuring this out myself a different way. i moved the timeline moving features around and it worked.
now what this one does is moves the timeline to before the extrude before it changes the text, and then moves it back to the end afterwards.
def run(context):
ui = None
try:
alphabet = ["A","B","C","D","E","F","G",'H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z', "( {\n[ <", ") }\n] >", ", ."]
for i in alphabet:
# Change the text.
legend = i
adsk.doEvents()
adsk.doEvents()
folder = "C:\\Users\\Zoe\\Desktop\\Keycaps\\set 1.5"
filename = folder + "\\" + skText.text + '.stl'
except:
if ui:
def run(context):
ui = None
try:
for i in alphabet:
# Change the text.
legend = i
adsk.doEvents()
adsk.doEvents()
except:
if ui:
I think that it is safer to roll the timeline back to a specific feature rather than counting how many steps to move the timeline marker.
Rename the letter extrusion as textExtrusion by right clicking on it in the timeline then run the script below:
import os
def run(context):
ui = None
try:
folder = r"C:\Users\Zoe\Desktop\Keycaps\set 1.5"
extrudes = rootComp.features.extrudeFeatures
for txt in alphabet:
textExtrusion = extrudes.itemByName('textExtrusion')
textExtrusion.timelineObject.rollTo(True)
# Change the text.
skText.text = txt
adsk.doEvents()
filename = os.path.join(folder, txt + '.stl')
except:
if ui:
import os
def run(context):
ui = None
try:
# Change the text.
skText.text = txt
adsk.doEvents()
except:
if ui:
