Hello, first of all, I do consider myself as a starter with Fusion 360. I am looking for a solution to have the ability to export to SVG files.
I saw this instructable , and this is exactly what I need. This is the first add-in, I'm trying to install.
I downloaded the add-in from the app store, installed it, but now I'm stuck. When I restart Fusion 360 it is not showing up.
Can anybody tell me what to do now? I am running Fusion version 2.0.6670.
Solved by JeromeBriot. Go to Solution.
The Shaper icon is under the TOOLS tab:
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Hi Jerome,
The tools tab no longer exists in Fusion 360. In the utilities tab the Shaper icon does not show for me. Do you know a solution?
Best, Pieter
@p.c.kooijman The TOOLS tab was renamed as UTILITIES.
Do you have a previous version of the add-in installed on your machine?
Go to UTILITIES > ADD-INS > Scripts and add-ins > Add-Ins. Do you see the ShaperUtilities item in the list ?
It was not in the Add-in list, nor the utilities tab.
I managed to fix it by installing the add-in again while Fusion was running (I presumed earlier that Fusion needed to be closed to install properly), and then restarting Fusion.
Thanks for your response!
