I just setup and installed the files found there: Fusion 360 Help | Palette Sample | Autodesk
Everything is working just as expected which is very nice and give me ideas for a plugin I have in mind.
The mystery is that, for example, I see as a title in the HTML document "Fusion 360 Palette Sample", but I can't find this string in either the .py file or the .html file.
I also added some css, like this:
<head>
<style>
body {font: normal, Verdana, Arial, sans-serif; font-size:large;}
p {color: rgb(38, 0, 255);}
</style>
</head>
but I can't see any difference in the displayed html, while I see it in VS Code (Extension HTML Preview), even after I stopped and restarted the plugin.
It would be a great help in using this feature to have those "mysteries" solved!
Happy New Year !
Solved by JeromeBriot. Go to Solution.
This is not the code of the add-in you created.
The documentation can be confusing:
Edit the add-in and check the code under the resources/html folder:
For the CSS, a good pratice is to use a separate file. You can add it in the resources/static folder.
For example style.css:
body {
background-color: lightcyan;
h1 {
color: peru;
font-weight: bold;
Then you call this file in the <head> section of the HTML file:
<head>
<meta charset="UTF-8">
<title>Title</title>
<link rel="stylesheet" type="text/css" href="static/style.css">
<script type="text/javascript" src="static/palette.js"></script>
</head>
You have to stop and run the add-in to see the modifications:
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Thank you for your answer, Jérôme. Yes, it was confusing. I'll take the time to look at this in depth tomorrow.
