Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
MemoryUsed add-in for Fusion 360
10 REPLIES 10
Message 1 of 11
JeromeBriot
1651 Views, 10 Replies
MemoryUsed is an add-in that displays the memory consumption of Fusion 360.
The amount of memory used is updated every second. The code works on Windows and on Mac.
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-memory-used
10 REPLIES 10
Message 2 of 11
JeromeBriot
in reply to: JeromeBriot
I updated the code to make it compatible with Python 3.7.3
Unfortunatly, I faced an issue with psutil 5.6.3 on Windows 7.
This is the same problem as reported here: [Win 7] memory_full_info() throw Permission denied Error in 5.6.3
Can someone can test it on Windows 7 or a newer version? Let me know if it works or not.
You can use the GitHub2Fusion360 script to install the add-in. See in my signature below.
Thanks.
Message 3 of 11
nzzconwa
This program can observe the state of memory leaks. Thanks.
Message 4 of 11
JeromeBriot
I fixed this issue. The add-in now works on Windows and Mac.
Message 5 of 11
JeromeBriot
A new version is available (0.5.0) :
Message 6 of 11
JeromeBriot
A new version is available (0.5.1) :
  • Fix a minor bug with parseInt in MUScript.js
Message 7 of 11
nzzconwa
Consider adding the monitoring virtual memory (page file, commit size) feature. Thank you.
Message 8 of 11
gtprototype
@JeromeBriot  I just installed your plug in and rebooted.  When I click the icon in the upper right to open the display I get an error message.  I have to click ok 5-6 times before the display opens.  Here is the error message:
Dale Speakes
prototype technology
Message 9 of 11
JeromeBriot
A new version is available (0.6.0) :
  • Update code for Python 3.9
  • Upgrade psutil to version 5.9.3
Message 10 of 11
JeromeBriot
A new version is available (0.7.0) :
  • Update code for Python 3.11
Message 11 of 11
JeromeBriot
A new version is available (0.8.0) :
  • Update code for Python 3.12
