Announcements
Setting description on a dataFile object fails. Bug or incorrect documentation?
Joshua.mursic
Joshua.mursic
I get this error when trying to change the description of a Data File:
AttributeError: property of 'DataFile' object has no setter
But the documentation says that the description property is read/write:
'Gets and sets the description information associated with this item.'
Is this a bug or is the documentation incorrect?
Jorge_Jaramillo
I believe it's an error in the documentation, because later in the Property Value description it says it's read only:
Jorge Jaramillo
Joshua.mursic
Thank you @Jorge_Jaramillo
