Solved by BrianEkins. Go to Solution.
That's strange. I have the Fusion version shown below and the C++ samples are working for me. I don't know if there was an issue specific to the version you had. Can you update and try it again?
Fusion 2.0.18961 x86_64
I reproduced the issue a few days ago on my machine but the C++ add-ins work now with Fusion 2.0.18950 x86_64 and 2.0.18961 x86_64.
Maybe a problem with the Autodesk servers?
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
@BrianEkins -San.
@JeromeBriot -San.
Thanks for confirming.
Ver 2.0.18961 did not work either.
I tried switching to English just to be sure, but it did not work.
I remember hearing about an issue where some of the samples were incorrectly being built using debug libraries. If you've installed the C++ development environment on your machine you'll have these libraries, but you won't have them with a standard Windows installation. The samples need to be rebuilt using Release libraries. I'm guessing that's the problem you've run into.
@BrianEkins -San.
I certainly do not have Visual Studio installed. Perhaps the Japanese forum members who told me have not installed it either.
