Python upgraded to 3.7.3 and Spyder replaced by VSCode (coming soon)
JeromeBriot
Mentor Mentor
Message 1 of 23
JeromeBriot
For those who don't read the Mod the Machine blog:
 - We are upgrading the Python version used in Fusion 360 to 3.7.3 in the September release.
 - We are also going to replace the editor from Spyder to VSCode in this release.
Full post here: New Python version and Visual Studio Code
The upgrade of Python was briefly mentionned 3 weeks ago by goyals in the Support forum (Update web browser coming with Fusion 360). But nothing yet about the replacement of Spyder by VSCode.
In my opinion, these information could have been posted in the API forum earlier.
By the way, thank you for these improvements.
Replies (22)
Message 21 of 23
rax2003_7
My spurgear script is not working either! using MaC
Message 22 of 23
rax2003_7
So, fixing your python script worked? I'm jsut doing first plugin and I can't get the correcto locations of my ocurrences. SpurGear script have failed, both python and c++ version(The C++ version crashes!).  Other scripts seem to do nothing. I'm using the latest version of both fusion and VS on Mac :/.
This is my plugin code, could you try it? it doesn't crash, it jsut returns the worng positions(posted here also: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/billboards-at-wrong-location/m-p/9063494😞
#Author- Raul Huertas
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def esPisoQ(componente):
    atributoPrevio = componente.attributes.itemByName('ITSTools', 'Tipo')
    if atributoPrevio :
        if atributoPrevio.value == "Piso" :
            return True
        else:
            return False
    else:
        return False
def esMaqQ(componente):
    if atributoPrevio :
        if atributoPrevio.value == "Maquina" :
            return True
        else:
            return False
    else:
        return False
def getN(componente, numeroStr):
    print("TIPO: ", type(componente) ,"\n")
    print("NOMBRE: ", (componente.fullPathName) ,"\n")
    atributoPrevio = componente.attributes.itemByName('ITSTools', 'N')
    if atributoPrevio :
        return atributoPrevio.value
    else:
        return ""
def nMaquinaExisteQ( numeroStr ):
    returnValue = false;
    app = adsk.core.Application.get()
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    occs = rootComp.occurrences
    for componente in occs:
        if isinstance(componente, adsk.fusion.Occurrence):
            atributoPrevio = componente.attributes.itemByName('ITSTools', 'NMaquina')
            if atributoPrevio :
                numeroStrActual = atributoPrevio.value
                if numeroStrActual==numeroStr :
                    returnValue = true
                    break
    return returnValue
def listar(componente):
    print("TRANSFORM: ", (componente.transform) ,"\n")
    print("TRANSFORM ARRAY: ", (componente.transform.asArray()) ,"\n")
def  ocultarVistaITS():
    # des = adsk.fusion.Design.cast(app.activeProduct)
    des = app.activeProduct
    root = des.rootComponent
    for graphGroup in root.customGraphicsGroups:
        if graphGroup.id == "ITSMarks":
            graphGroup.deleteMe()
            break
    return
def  actualizarVistaITS():
    ocultarVistaITS()
    graphics = root.customGraphicsGroups.add()
    graphics.id = "ITSMarks"
    pointIndices = [0];
    occs = root.occurrences
        listar(componente)
        if esMaqQ (componente):
            # coordsOrg = adsk.core.Vector3D.create(0,0,0)
            # coordsOrg.transformBy(componente.transform)
            # coords = adsk.fusion.CustomGraphicsCoordinates.create([componente.transform.translation.x, componente.transform.translation.y, componente.transform.translation.z])
            # points = graphics.addPointSet(coords, pointIndices,
            #             adsk.fusion.CustomGraphicsPointTypes.UserDefinedCustomGraphicsPointType,
            #             'resourcesMaquina/32x32@2x.png')
            identityMatrix = adsk.core.Matrix3D.create()
            graphicsText = graphics.addText("Maquina", 'Arial', 50, identityMatrix)
            # point = componente.boundingBox.minPoint
            point = componente.transform.translation
            billBoard = adsk.fusion.CustomGraphicsBillBoard.create(
                adsk.core.Point3D.create(point.x, point.y, point.z)
            billBoard.billBoardStyle = adsk.fusion.CustomGraphicsBillBoardStyles.ScreenBillBoardStyle
            graphicsText.billBoarding = billBoard
            adsk.doEvents()
        elif esPisoQ(componente):
            #             'resourcesPiso/32x32@2x.png')
            text = 'Piso'
            matrix = adsk.core.Matrix3D.create()
            # matrix.translation = componente.transform.translation
            graphicsText = graphics.addText(text, 'Arial', 50, matrix)
            # billBoard = adsk.fusion.CustomGraphicsBillBoard.create(adsk.core.Point3D.create(componente.transform.translation.x, componente.transform.translation.y, componente.transform.translation.z))
            (origin, xAxis, yAxis, zAxis) = componente.transform.getAsCoordinateSystem()
            billBoard = adsk.fusion.CustomGraphicsBillBoard.create(origin)
            adsk.doEvents()
    app.activeViewport.refresh()
def configurarComoPiso(componente):
    # ui.messageBox(type(componente))
    # ui.messageBox('componente.fullPathName)
    if atributoPrevio :
        if atributoPrevio.value != "Piso" :
            componente.attributes.add('ITSTools', 'Tipo', "Piso");
    else:
        # print(componente.fullPathName, " configurado como Piso\n")
def configurarComoMaquina(componente):
    if atributoPrevio :
        if atributoPrevio.value != "Maquina" :
            componente.attributes.add('ITSTools', 'Tipo', "Maquina");
    else:
        # print(componente.fullPathName, " configurado como Maquina\n")
def desmarcar(componente):
    if atributoPrevio :
        atributoPrevio.deleteMe()
# global mapping list of event handlers to keep them referenced for the duration of the command
#handlers = {}
handlers = []
cmdDefs = []
selection = []
botonMostrar = None
botonOcultar = None
def run(context):
    ui = None
    handlers.clear()
    try:
        ui  = app.userInterface
        def setLinearMarkingMenu(args):
            try:
                menuArgs = adsk.core.MarkingMenuEventArgs.cast(args)
                commands = []
                linearMenu = menuArgs.linearMarkingMenu
                if args.selectedEntities:
                    sel0 = args.selectedEntities[0]
                    if isinstance(sel0, adsk.fusion.Occurrence):
                        linearMenu.controls.addSeparator('LinearSeparator')
                        if(esPisoQ(sel0)):
                            cmdDefSpecial = ui.commandDefinitions.itemById('ITSIndPiso')
                            linearMenu.controls.addCommand(cmdDefSpecial)
                        if(esMaqQ(sel0)):
                            cmdDefSpecial = ui.commandDefinitions.itemById('ITSIndMaq')
                        cmdDefSpecial = ui.commandDefinitions.itemById('ITSPisoCommand')
                        cmdDefSpecial = ui.commandDefinitions.itemById('ITSMaquinaCommand')
                        cmdDefSpecial = ui.commandDefinitions.itemById('ITSDesmarcarCommand')
            except:
                if ui:
                    ui.messageBox('setting linear menu failed: {}').format(traceback.format_exc())
        def setRadialMarkingMenu(args):
            try:
            except:
                if ui:
                    ui.messageBox('setting radial menu failed: {}').format(traceback.format_exc())
        class MarcarComoITSHandler(adsk.core.CommandCreatedEventHandler):
            def __init__(self):
                super().__init__()
            def notify(self, args):
                try:
                    command = args.command
                    onCommandExcute = MarcarComoITSExecuteHandler()
                    handlers.append(onCommandExcute)
                    command.execute.add(onCommandExcute)
                except:
                    ui.messageBox('command created failed: {}').format(traceback.format_exc())
        class MarcarComoITSExecuteHandler(adsk.core.CommandEventHandler):
            def __init__(self):
                super().__init__()
                try:
                    command = args.firingEvent.sender
                    cmdDef = command.parentCommandDefinition
                    if cmdDef:
                        if cmdDef.id == 'ITSPisoCommand':
                            if selection:
                                for componenteEntity in selection:
                                    configurarComoPiso(componenteEntity)
                            else:
                                ui.messageBox('No hay componente seleccionado.')
                        elif cmdDef.id == 'ITSMaquinaCommand':
                            if selection:
                                    configurarComoMaquina(componenteEntity)
                            else:
                        elif cmdDef.id == 'ITSDesmarcarCommand':
                            if selection:
                                    desmarcar(componenteEntity)
                            else:
                        elif cmdDef.id == 'ITSMostrarCommand':
                        elif cmdDef.id == 'ITSOcultarCommand':
                            ocultarVistaITS()
                    else:
                        ui.messageBox('No hay definición de comando')
                except:
                    if ui:
                        ui.messageBox('Error ejecutando comando: {}'.format(traceback.format_exc()))
        class MyMarkingMenuHandler(adsk.core.MarkingMenuEventHandler):
            def __init__(self):
                super().__init__()
                try:
                    # selected entities
                    global selection
                    selection.clear()
                    selection = args.selectedEntities
                except:
                    if ui:
                        ui.messageBox('Marking Menu Displaying event failed: {}'.format(traceback.format_exc()))
        # Add customized handler for marking menu displaying
        onMarkingMenuDisplaying = MyMarkingMenuHandler()
        handlers.append(onMarkingMenuDisplaying)
        ui.markingMenuDisplaying.add(onMarkingMenuDisplaying)
        # Add customized handler for commands creating
        onCommandCreated = MarcarComoITSHandler()
        handlers.append(onCommandCreated)
        # CREAR COMANDOS
        # Para indicar si es maquina
        ITSIndMaq = ui.commandDefinitions.itemById('ITSIndMaq')
        if not ITSIndMaq:
            ITSIndMaq = ui.commandDefinitions.addButtonDefinition('ITSIndMaq', 'Tipo Actual: Máquina', 'Indica que este componente es máquina.', './resourcesITSLogo')
            ITSIndMaq.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSIndMaq)
        ITSIndPiso = ui.commandDefinitions.itemById('ITSIndPiso')
        if not ITSIndPiso:
            ITSIndPiso = ui.commandDefinitions.addButtonDefinition('ITSIndPiso', 'Tipo Actual: Piso', 'Indica que este componente es piso.', './resourcesITSLogo')
            ITSIndPiso.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSIndPiso)
        # Para crear maquinas
        ITSMaquinaCommand = ui.commandDefinitions.itemById('ITSMaquinaCommand')
        if not ITSMaquinaCommand:
            ITSMaquinaCommand = ui.commandDefinitions.addButtonDefinition('ITSMaquinaCommand', 'Marcar como Máquina...', 'Marca este componente como máquina.', './resourcesITSLogo')
            ITSMaquinaCommand.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSMaquinaCommand)
        # Para crear pisos
        ITSPisoCommand = ui.commandDefinitions.itemById('ITSPisoCommand')
        if not ITSPisoCommand:
            ITSPisoCommand = ui.commandDefinitions.addButtonDefinition('ITSPisoCommand', 'Marcar como Piso...', 'Marca este componente como piso.', './resourcesITSLogo')
            ITSPisoCommand.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSPisoCommand)
        # Para desmarcar
        ITSDesmarcarCommand = ui.commandDefinitions.itemById('ITSDesmarcarCommand')
        if not ITSDesmarcarCommand:
            ITSDesmarcarCommand = ui.commandDefinitions.addButtonDefinition('ITSDesmarcarCommand', 'Desmarcar...', 'Quita cualquier atributo de ITS.', './resourcesITSLogo')
            ITSDesmarcarCommand.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSDesmarcarCommand)
        # ui.messageBox('Right click to see the customized marking menu.')
        #CREAR BOTON EN EL PANEL DE HERRAMIENTAS
        global botonMostrar
        global botonOcultar
        ITSMostrarCommand = ui.commandDefinitions.itemById('ITSMostrarCommand')
        if not ITSMostrarCommand:
            ITSMostrarCommand = ui.commandDefinitions.addButtonDefinition('ITSMostrarCommand', 'Mostrar roles',
                                            'Muestra los roles de cada componente',
                                            './resourcesOjoSI')
            ITSMostrarCommand.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSMostrarCommand)
            panelObjetivo = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
            botonMostrar = panelObjetivo.controls.addCommand(ITSMostrarCommand)
            botonMostrar.isPromotedByDefault = True
            botonMostrar.isPromoted = True
        ITSOcultarCommand = ui.commandDefinitions.itemById('ITSOcultarCommand')
        if not ITSOcultarCommand:
            ITSOcultarCommand = ui.commandDefinitions.addButtonDefinition('ITSOcultarCommand', 'Ocultar roles',
                                            'Oculta los roles',
                                            './resourcesOjoNO')
            ITSOcultarCommand.commandCreated.add(onCommandCreated)
            cmdDefs.append(ITSOcultarCommand)
            botonOcultar = panelObjetivo.controls.addCommand(ITSOcultarCommand)
            botonOcultar.isPromotedByDefault = True
            botonOcultar.isPromoted = True
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        # ocultarVistaITS()
        for obj in cmdDefs:
            if obj.isValid:
                obj.deleteMe()
            else:
                ui.messageBox(str(obj) + ' is not a valid object')
        handlers.clear()
        global botonMostrar
        global botonOcultar
        botonMostrar.deleteMe()
        botonOcultar.deleteMe()
        # ui.messageBox('Stop addin')
    except:
        if ui:
Message 23 of 23
Rushikesh.kadam
Hi @PinRudolf
Thank you for your feedback and time.
We have logged an issue UP-43773 - Allow User to run script from VSCode. We will get back to you with solution.
Rushikesh Kadam
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
