Python script to create a chain of lines
cadTPLWJ
cadTPLWJ
Code below is a script example.
Suppose I want lines between the points instead of the spline line, how would I do that?
Do I have to individually name all the little lines or can I make some kind of line collection?
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
        # Create an object collection for the points.
        points = adsk.core.ObjectCollection.create()
        # Define the points the spline with fit through.
        points.add(adsk.core.Point3D.create(0, 0, 0))
        points.add(adsk.core.Point3D.create(5, 1, 0))
        points.add(adsk.core.Point3D.create(6, 4, 3))
        points.add(adsk.core.Point3D.create(7, 6, 6))
        points.add(adsk.core.Point3D.create(2, 3, 0))
        points.add(adsk.core.Point3D.create(0, 1, 0))
        # Create the spline.
        sketch.sketchCurves.sketchFittedSplines.add(points)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
There is no API to create a chain of lines like what we create spline. However you should be able to create the lines one by one. Please refer to the codes as below:
def run(context):
    ui = None
    try:
        for i in range(points.count-1):
            pt1 = points.item(i)
            pt2 = points.item(i+1)
            sketch.sketchCurves.sketchLines.addByTwoPoints(pt1, pt2)
    except:
        if ui:
Marshal
ekinsb
The code that Marshal gave you is good and will work.  However, the result may be slightly different than what you expect.  It creates five completely independent lines.  Their endpoints happen to be at the same coordinate but if you use the mouse to drag one of the end points you'll find that the lines are not connected.  Here's a slight change to the above code so that existing sketch points are used to create the new lines.
            if i == 0:
            else:
                pt1 = lastLine.endSketchPoint
            lastLine = sketch.sketchCurves.sketchLines.addByTwoPoints(pt1, pt2)
Brian Ekins
Mod the Machine blog
JeromeBriot
Same code for a closed polygon:
    lines = sketch.sketchCurves.sketchLines
    pt1 = points.item(0)
    pt2 = points.item(1)
    firstLine = lines.addByTwoPoints(pt1, pt2)
    lastLine = firstLine
    for i in range(1,points.count-1):
        lastLine = lines.addByTwoPoints(pt1, pt2)
    pt2 = firstLine.startSketchPoint
Hi Brian,
this is cool...it works, but could you explain what's happening, I try to wrap my head around it but I'm having a hard time.
Let's say I was trying to make a sketch of a closed square. I wrote this:
points.add(adsk.core.Point3D.create(0,0,0))
points.add(adsk.core.Point3D.create(0,2,0))
points.add(adsk.core.Point3D.create(2,2,0))
points.add(adsk.core.Point3D.create(2,0,0))
Then I added your lines and it works, I have a closed square in a sketch. But...how? So if I am not mistaken: adsk.core.ObjectCollection.create() creates an object called "points" that will include the points below. How does it put it in my sketch?
Also,  can you break down your loop? I'm sorry if I'm asking too much or if I sound like a newb...I did coding in college 12 years ago and I'm trying to dig this back to the surface of my memory but it's hidden way deep in there
Thanks a lot, I appreciate it 🙂
