NoGestures add-on from Pawel Inc. [support]
pawelzwronek
Message 1 of 89
pawelzwronek
NoGesturesNoGestures
Hi and thx for using my second add-on for Fusion 360 NoGestures
If you encounter any problem feel free to write in this thread 🙂
Replies (88)
Message 61 of 89
devon.pucel
Observer
Observer
I am pretty sure the lately update broken this. Can anyone else confirm?
Message 62 of 89
pawelzwronek
Thx for the info. Same for me but fixed using the best IT solution, turning off and on fusion 🙂
Message 63 of 89
peterfrandsen
Community Visitor
Community Visitor
When i want to just use the right click menu, it takes like 2 seconds to pop up, could you make a version of the script that just disables the gestures drawing thing so RMB is only used for the right-click menu?
Message 64 of 89
ejdiamond
@pawelzwronek
In today's update: September 19, 2023
Fusion 360 2.0.17244 x86_64
I am seeing this:
SCRIPT ERROR
Traceback (most recent call last):
File "C:/Users/ejdia/AppData/Roaming/Autodesk/ApplicationPlugins/NoGesturesNoShift.bundle/Contents/NoGesturesNoShift.py", line 59, in <module>
pyt = os.path.join(os.path.split(os.__file__)[0], '..\\python')
AttributeError: module 'os' has no attribute '__file__'
... and the addin appears inoperable.
Same result after multiple restarts.
Message 65 of 89
pawelzwronek
Thanks for reporting, it's fixed 🙂 Python version changed to 3.11 and I had to rebuild one binary file. I will submit it to the shop soon and for now you can replace manually attached files in C:/Users/ejdia/AppData/Roaming/Autodesk/ApplicationPlugins/NoGesturesNoShift.bundle
Message 66 of 89
pawelzwronek
For me it's about 1 sec and true it's quite long. I've tried reduce this lag but no luck 😞
Message 67 of 89
ejdiamond
Perfect -- thank you sir!
Message 68 of 89
awelton00
@pawelzwronek
They broke it again. I'm on 2.0.17721
Do you have any way to accept donations? This add-on is the only thing that makes fusion usable for me.
Message 69 of 89
adamPTCLE
Observer
Observer
I would also happily donate. I agree that this add-in is the only thing that makes fusion usable for me
Message 70 of 89
pawelzwronek
Dont know why but removing __pycache__ folder at C:\Users\%USERNAME%\AppData\Roaming\Autodesk\ApplicationPlugins\NoGestures.bundle\Contents\pyHook and restarting Fusion360 did the thing for me 🤔 Alternative is reinstalling NoGestures addin.
@awelton00 @adamPTCLE donation is not needed, a kind word is enough
Message 71 of 89
awelton00
Weirdly enough deleting pycache didn't work, but removing and reinstalling did the trick. Thanks!
Message 72 of 89
ryanreed1
Community Visitor
Community Visitor
The lag is still there for me even after reinstalling, or removing the pycache folder. Such a shame as I'd love this addon to work, hate having to hold down shift to switch between orbit and pan.
Message 73 of 89
pawelzwronek
I'm unable to remove the lag, it's present since the beginning. For non-shift version try NoGesturesNoShift
Message 74 of 89
ejdiamond
@pawelzwronek It looks like today's update broke NoGesturesNoShift v1.7
There are no messages in my message panel
I have uninstalled and reinstalled 😞
Fusion 2.0.20256 x86_64
Active Plan: Personal
Windows 11 Pro 23H2 (22631.4169)
Thank you!
Message 75 of 89
JeromeBriot
This is due to the upgrade of Python with the latest version of Fusion: Fusion has updated its Python version to 3.12.4 in this release.
@pawelzwronekhas to update some pyc files. In the meantime, you can't use this add-in.
Message 76 of 89
CapGuy
Hello @ejdiamond ,
Instead of waiting the update, did you try to uncheck "Use gesture-based view navigation" in Preferences/General, (and by the way did you try to choose "Tinkercad" within "Pan, Zoom, Orbitshortcuts" pop-up menu) ?
Hoping this will help a bit,
Guy
May The Force be...yond !
Message 77 of 89
pawelzwronek
Quick fix: put attached _cpyHook.cp312-win_amd64.pyd inside pyHook folder. C:\Users\%USERNAME%\AppData\Roaming\Autodesk\ApplicationPlugins\NoGestures.bundle\Contents\pyHook
Message 78 of 89
pawelzwronek
New version 2.0 is released NoGestures NoGesturesNoShift
- fix hung up on rapid RMB clicks
- better RMB response
- pure python implementation, no SWIG binaries
Message 79 of 89
silvernull
Is there a way to use nogestures just for having just gestures be disabled, but not pan using RMB?
Message 80 of 89
pawelzwronek
@silvernull  you can edit C:\Users\%USERNAME%\AppData\Roaming\Autodesk\ApplicationPlugins\NoGestures.bundle\Contents\NoGestures.py and change rmbAsOrbit = False to rmbAsOrbit = True at line 34. Play also with switchRMB_MMB.
