NoGestures add-on from Pawel Inc. [support]
pawelzwronek
Message 1 of 89
pawelzwronek
NoGesturesNoGestures
Hi and thx for using my second add-on for Fusion 360 NoGestures
If you encounter any problem feel free to write in this thread 🙂
Replies (88)
Message 81 of 89
victorkameleon
Observer
Observer
I firstly installed NoGestures and then I installed NoGesturesNoShift and now it doesn't work. I've uninstalled both add-ins and even Fusion itself but it doesn't work 😞 I have it working on my office computer but not on my home computer. Do you know how to resolve this? It's showing in Fusion that it's up and running and no error messages.
Thanks in advance & great add-in, can't live without it!
Message 82 of 89
pawelzwronek
It's hard to replicate this situation on my PC @victorkameleon  It's working for me even when both addons are running at the same time.
You can try to enable logging to a file:
- open C:\Users\%USERNAME%\AppData\Roaming\Autodesk\ApplicationPlugins\NoGestures.bundle\Contents\NoGestures.py and change logToFile= False to logToFile= True at line 38
- restart whole Fusion or the NoGestures addon only
- find 2 files named like NoGestures_<random letters>.log: in C:\Users\%USERNAME%\AppData\Local\Temp
- post them here
Message 83 of 89
victorkameleon
Observer
Observer
Sorry for the late answer. See the file attached in this answer.
Message 84 of 89
pawelzwronek
There should be 2 files with the same date. Post them both please.
Message 85 of 89
victorkameleon
Observer
Observer
I only find these two after restarting Fusion again in C:\Users\%USERNAME%\AppData\Local\Temp
Message 86 of 89
pawelzwronek
Now I see the problem. It was a space character in your username 🙂
To fix replace line 83 and 84 to:
    args = [pyt, __file__, 'main']
    log('running subprocess: ' + str(args))
    process = subprocess.Popen(args, startupinfo=si)
Message 87 of 89
victorkameleon
Observer
Observer
Doesn't seem right to replace line 83 & 84? This is NoGesturesNoShift it differs between them.
Message 88 of 89
pawelzwronek
Yep. In NoGesturesNoShift  it's 79 and 80.
Thanks for reporting this issue. You must be the first person with a space in username on windows 🙂
Message 89 of 89
victorkameleon
Observer
Observer
That did the trick!
Thank you so much for an awesome add-in, can't live without it! 😄
And also thanks for the quick and awesome support, you rock!
