Need help with Pinion Tooth Profile API
Beyondforce
Advisor Advisor
Beyondforce
Hey all,
I'm new to API scripting and I was hopping someone can help me to translate these 2 X and Y equation to a python script.
X equation: 30.3161 * (cos(0.9020 * u) + 0.9020 * u * sin(0.9020 * u))
Y equation: 30.3161 * (sin(0.9020 * u) - 0.9020 * u * cos(0.9020 * u))
Umin, Umax, Ustep: 0, 1, 10
This script is originally from a Blender tutorial guide, and if someone knows how to do it in Fusion, that will be a huge help.
Cheers / Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
ekinsb
I believe this script will do what you want.
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        if app.activeEditObject.objectType != adsk.fusion.Sketch.classType():
            ui.messageBox('A sketch must be active.')
            return
        sk = adsk.fusion.Sketch.cast(app.activeEditObject)
        uMin = 0
        uMax = 1
        steps = 10
        pnts = adsk.core.ObjectCollection.create()
        for i in range(10):
            uVal = uMin + ((uMax - uMin) * (i/(steps-1)))
            x = 30.3161 * (math.cos(0.9020 * uVal) + 0.9020 * uVal * math.sin(0.9020 * uVal))
            y = 30.3161 * (math.sin(0.9020 * uVal) - 0.9020 * uVal * math.cos(0.9020 * uVal))
            pnts.add(adsk.core.Point3D.create(x,y,0))
        sk.sketchCurves.sketchFittedSplines.add(pnts)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
Beyondforce
@ekinsb, Thank you very much. It works like a charm!! 🙂
Now that I have the Tooth profile and I finish creating the gear, it looks like this (exactly as I want it):
Now I need to curve all the teeth upwards like this:
I have a script that should do the trick, but I don't know how to turn it into Fusion pyhtone and to apply it to the above sketch:
	Hide pinion script
import bpy
from math import *
obj=bpy.context.object
mesh=obj.data
for i in range(0, len(mesh.vertices)):
 vert=mesh.vertices[i]
 x=vert.co[0]
 y=vert.co[1]
 z=vert.co[2]
 R=33.037
 alpha=13.702*pi/180
 r=sqrt(x*x+y*y)
 teta=atan2(y, x)
 rnew=R+(r-R)*cos(alpha)
 xnew=rnew*cos(teta)
 ynew=rnew*sin(teta)
 znew=(r-R)*sin(alpha)
 vert.co[0]=xnew
 vert.co[1]=ynew
 vert.co[2]=znew
Thank you so much for the help 🙂
Cheers / Ben.
Ben Korez
| YouTube
ekinsb
Fusion is creating analytic geometry, both as the sketch geometry and surfaces and solids.  They are not a mesh that can be deformed.  I suspect you can still accomplish what you want but need to look at it differently than you have previously.  It seems like you can extrude your existing sketch and then create another sketch, possibly an arc, that you then revolve around the axis of the gear to remove the material and round the bottom of the gear.
Brian Ekins
Beyondforce
I had a feeling you would say that.
Thanks a lot for that help!
Ben.
Ben Korez
| YouTube
