Sequencer Object
Sequencer Object
Sequencer Object
I'm trying to write a script to change to the sequencer function instead of using the auto number script. I'm not entirely sure on where to put the script to make it work to change the objects that I want changed. My code so far is:
var seq = Sequencer.get('Q', 1, 1);
var value = seq.nextValue();
item.SEQUENCER = 'Quote' + value;
ekinsb
I don't know what you're referring to in regards to the "auto number script".
Brian Ekins
Mod the Machine blog
Capture.PNGI'm trying to switch from the auto number to the sequencer since the auto number sometimes skips over numbers in order.
ekinsb
Is this in Fusion 360?  If so, there isn't any API support for this.
Brian Ekins
I think I posted this to wrong forum, I wasn't sure where to get help with this problem, sorry.
ekinsb
I'm not familiar with that dialog and don't know which product you're using but there should be a forum where you can ask your question.  Just a guess but here are links to the Fusion Connect and Fusion Lifecycle forums.
Brian Ekins
