Keyshot 9: Fusion 360 giving error message Live link failed
Message 1 of 12
Fusion 360 giving error message Live link failed. Reason: "Failed to connect. Could not get a scene api. Please check your Keyshot installation."
https://apps.autodesk.com/FUSION/en/Detail/Index?id=727915862713285438&appLang=en&os=Win64
Replies (11)
Message 2 of 12
Rushikesh.kadam
@Anonymous I get this message when have installed only KeyShot plugin and not the KeyShot software. Can you check if KeyShot software is installed and working ? This extension will work only if KeyShot is installed. Link to download the software is present in description of KeyShot 9 Autodesk Fusion 360 Plugin.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=727915862713285438&os=Win64&appLang=en
If it works out, do click on accept solution button.
Rushikesh Kadam.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Message 3 of 12
Hi I got the same error message.. when I'm trying to export model from Fusion 360 to Keyshot 9.0 pro
this is the message:
and after I read the solution I checked the settings in Keyshot 9 and the Live linking is Enabled...
This is PRTSCRN from my settings.
Do you know how to fix this problem?
Thanks for help.
Yanai
Message 4 of 12
Did you solved this problem.
I have the same problem.
using keyshot 9 and fusion plugin.
thanks
Message 5 of 12
Hi, do you Solve this problem? I have the same issues.. 😞
Message 6 of 12
martin.miguel
Observer
Observer
If you're getting the "could not get scene api" problem, try this:
On a Windows PC, enter the Registry Editor by hitting the 'Windows' Key and typing 'Reged'. Check the Registry Entry for: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Luxion\KeyShot. Confirm that 'ResourceFolder' and 'Resources' lead to the same file path. If not, confirm where Resources are located and then edit the Registry to match that exact filepath by right-clicking the wrong entries and selecting 'modify'.
Worked like a charm for me
Message 7 of 12
alex.batistaV3XKC
This worked fine for me. Thanks!! 🙂
Message 8 of 12
pranav97jain
I am also facing the same problem. There is no registry with name luxion in my system. How do I solve this problem?
Message 9 of 12
nathanvarghese777
Community Visitor
Community Visitor
Same problem here
Message 10 of 12
peter.reibel
Kudos go to a Chinese website I stumbled upon:
I'm using the newly released KeyShot 11 with a subscription license on Windows 11 Pro.
I manually added the string values "ResourceFolder" and "Resources" stated above to the also stated above "Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Luxion\KeyShot" registry folder (Note: the folder will be named with the KeyShot main version attached, i.e.: "...\Luxion\KeyShot 11".
Add the path from the KeyShot preferences "Folders" pane under "Specifiy location for all Folders > Resources" (see screenshots) and you should immediately be ready to go.
Message 11 of 12
henning.spier
Hey!
i think i have tried every possible way to make the plugin work... without success. Im on the latest versions of fusion360 and keyshot 2024.1. The error message "Live link failed..." still occurs. Help would be much appriciated 😉.
Edit: Oh my! I just found the new plugin on the keyshot website and everything is fine!
Message 12 of 12
lukas_ingoldUTA97
New Member
New Member
Works !! i did need to add the 'Resource Folder' and 'Resources' Registry and change their content but that made Fusion360 talk to Keyshot and enabled the live linking for me.
