input string to setup sheet
TechrimStandards
Message 1 of 1
TechrimStandards
Hello!
So I've made a popup that asks for what pucks we want to remove on our fixture for setup. How do I create the input string as a property to then put into the excel setup sheet?
#Author-
#pop up for pucks
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        pucks= ui.inputBox('What pucks would you like to remove?','Puck Selction')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
            pucks=ui.inputBox('What pucks would you like to remove?','Puck Selction')
    while True:
        pucks=pucks[0]
        pucks.split(' ')
        for i in pucks:
            if i[0].isalpha == False:
                ui.messageBox('Please type a valid puck number','PuckError')
                continue
            else:
                break
Replies (0)
