Message 1 of 1
input string to setup sheet
- Mute
- Permalink
- Report
Hello!
So I've made a popup that asks for what pucks we want to remove on our fixture for setup. How do I create the input string as a property to then put into the excel setup sheet?
#Author-
#pop up for pucks
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
pucks= ui.inputBox('What pucks would you like to remove?','Puck Selction')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
pucks=ui.inputBox('What pucks would you like to remove?','Puck Selction')
while True:
pucks=pucks[0]
pucks.split(' ')
for i in pucks:
if i[0].isalpha == False:
ui.messageBox('Please type a valid puck number','PuckError')
continue
else:
break
