Visual Studio Code not being launched for editing fusion scripts ?
Dear All,
It is very odd and quite frustrating that I just learning fusion API and scripts programming via Visual Studio Code with no problem for few weeks and found very interesting and useful. However, it no longer being able to open Visual Studio Code for the editing, it run over the window /system32/cmd.exe for about 0.1 second only.
hence, I have tried to uninstall Visual Studio Code and Fusion 360, delete the C:/Users/user name/.vscode/ folder then download Fusion 360 and reinstall. then by clicking the Edit button for a script, the Fusion 360 directed for downloading the VS Code and completed the installation. the Fusion 360 is closed and restarted , and it directed the successful installation of VS Code extensions. However, when clicking the Edit button for a script, it just run over the window /system32/cmd.exe for about 0.1 second without opening a VS Code window for editing or debug the script. Repeating these cycle has experienced same results, which confused me if I need to try all these setting and tests on another PC ?
So, I wonder if there solutions for these barriers / exceptions ? Also, if any Configuration SOP or file so that I can put it in manually for building correct link and co-works between Fusion and VS Code ?
best regards !
