propertyValue = sketch_var.isActive
MichaelT_123
Advisor Advisor
MichaelT_123
Hi TF360,
Could you consider adding isActive property to the SketchObject class?
Property Value
This is a read only property whose value is a boolean.
Regards
MichaelT
MichaelT
kandennti
Hi @MichaelT_123 -San.
Why not prepare your own functions and use them as extended methods?
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        fusion.Sketch.isActive = is_active_sketch
        skt: fusion.Sketch = root.sketches[0]
        app.log(f"{skt.isActive()}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def is_active_sketch(self: fusion.Sketch) -> bool:
    des: fusion.Design = self.parentComponent.parentDesign
    return des.activeEditObject == self
MichaelT_123
Hi Kandennti-San,
It is a good solution that is already at hand. Thank you for pointing it out. I have missed the design.activeEditObject !!!
Regards
MichaelT
MichaelT
