extrudeFeatures.add should return null if the creation failed
JeromeBriot
Mentor Mentor
Message 1 of 1
JeromeBriot
A simple code that obviously failed because the profile is "outside" the B-Rep body to cut:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComponent = design.rootComponent
        sketches = rootComponent.sketches
        sketchesPlane = rootComponent.xYConstructionPlane
        sketch1 = sketches.add(sketchesPlane)
        sketch1.name = 'Square'
        lines = sketch1.sketchCurves.sketchLines;
        lines.addTwoPointRectangle(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(2, 2, 0))
        sketch2 = sketches.add(sketchesPlane)
        sketch2.name = 'Hole'
        circles = sketch2.sketchCurves.sketchCircles
        circles.addByCenterRadius(adsk.core.Point3D.create(3, 1, 0), 0.5)
        extrudes = rootComponent.features.extrudeFeatures
        extrudeInput1 = extrudes.createInput(sketch1.profiles.item(0), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(2.0)
        extrudeInput1.setSymmetricExtent(distance, True)
        extrude1 = extrudes.add(extrudeInput1)
        extrudeInput2 = extrudes.createInput(sketch2.profiles.item(0), adsk.fusion.FeatureOperations.CutFeatureOperation)
        extrudeInput2.participantBodies = [extrude1.bodies.item(0)]
        distance = adsk.core.ValueInput.createByReal(1.0)
        extrudeInput2.setSymmetricExtent(distance, True)
        extrude2 = extrudes.add(extrudeInput2)
        if extrude2 is None:
            ui.messageBox('Extrude Failed')
        sketch1.isVisible = True
        sketch2.isVisible = True
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The documentation says that extrudes.add should return null but in fact, it returns an error: No target body found to cut or intersect!
More, the code runs with success when the line with participantBodies is uncommented.
The only workaround to the error message I found is:
        try:
            extrude = extrudes.add(extrudeInput)
        except:
According to the documentation, in both cases it should be:
        if extrude is None:
Replies (0)
