Cut a B-Rep body with multiple profiles at once
JeromeBriot
Mentor Mentor
JeromeBriot
I can't figure out how to cut a B-Rep body with multiple profiles at once:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        allProfiles = False
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComponent = design.rootComponent
        sketches = rootComponent.sketches
        sketchesPlane = rootComponent.xYConstructionPlane
        sketch1 = sketches.add(sketchesPlane)
        sketch1.name = 'Square'
        lines = sketch1.sketchCurves.sketchLines;
        lines.addTwoPointRectangle(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(4, 4, 0))
        sketch2 = sketches.add(sketchesPlane)
        sketch2.name = 'Hole'
        circles = sketch2.sketchCurves.sketchCircles
        circles.addByCenterRadius(adsk.core.Point3D.create(1, 1, 0), 0.5)
        circles.addByCenterRadius(adsk.core.Point3D.create(1, 3, 0), 0.5)
        circles.addByCenterRadius(adsk.core.Point3D.create(3, 3, 0), 0.5)
        circles.addByCenterRadius(adsk.core.Point3D.create(3, 1, 0), 0.5)
        extrudes = rootComponent.features.extrudeFeatures
        extrudeInput = extrudes.createInput(sketch1.profiles.item(0), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(1.0)
        extrudeInput.setSymmetricExtent(distance, True)
        extrudes.add(extrudeInput)
        if allProfiles:
            extrudeInput = extrudes.createInput(sketch2.profiles, adsk.fusion.FeatureOperations.CutFeatureOperation)
        else:
            for profile in sketch2.profiles:
                extrudeInput = extrudes.createInput(profile, adsk.fusion.FeatureOperations.CutFeatureOperation)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The above code failed when allProfiles is set to True.
Thanks.
JeromeBriot
OK, I found the answer there: Extruding profile collection in single operation?
#Author-
#Description-
def run(context):
    ui = None
    try:
        profs = adsk.core.ObjectCollection.create()
        for prof in sketch2.profiles:
            profs.add(prof)
        extrudeInput = extrudes.createInput(profs, adsk.fusion.FeatureOperations.CutFeatureOperation)
    except:
        if ui:
I tried to create an object collection before asking for help here. But I made a mistake trying to populate the collection with all the profiles in one line:
profs.add(sketch2.profiles) # This line is wrong
