occurence.transform is super slow
JeromeBriot
Mentor Mentor
JeromeBriot
I try to improve the speed of my "Import IDF" add-in.
Basically, the code creates a board and places electrical components on it. So I heavily use the occurence.transform property. And this transformation takes ages even in its simpliest form.
import adsk.core, adsk.fusion, adsk.cam, traceback
import time
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        design.designType = adsk.fusion.DesignTypes.DirectDesignType
        rootComponent = design.rootComponent
        trans = adsk.core.Matrix3D.create()
        occ = rootComponent.occurrences.addNewComponent(trans)
        firstComp = occ.component
        firstComp.name = '0'
        sketches = firstComp.sketches
        sketchesPlane = firstComp.xYConstructionPlane
        sketch1 = sketches.add(sketchesPlane)
        sketch1.name = 'Square'
        lines = sketch1.sketchCurves.sketchLines;
        lines.addTwoPointRectangle(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(2, 2, 0))
        extrudes = firstComp.features.extrudeFeatures
        extrudeInput1 = extrudes.createInput(sketch1.profiles.item(0), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(2.0)
        extrudeInput1.setSymmetricExtent(distance, True)
        extrudes.add(extrudeInput1)
        start_time = time.time()
        for i in range(0, 200):
            occ = rootComponent.occurrences.addExistingComponent(firstComp, trans)
#            occ.transform = trans
        elapsed_time = time.time() - start_time
        app.activeViewport.refresh()
        adsk.doEvents()
        ui.messageBox('{:.2f} s'.format(elapsed_time))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
On my machine, it takes 5 seconds to create 200 occurences. Now if I uncomment the line with the transform action, the same code takes 18 seconds to finish. It's approximatly x4 just for a matrix product!
Note that I can't use the Component.transformOccurrences method because as I said before, in my real design, there are many different components (up to 1500).
For example, my add-in takes 26 seconds to create 277 components. It takes 74 seconds to create the same components with transformation. And the elapsed time is not linear. It's getting worst and worst.
Do you have any idea to accelerate this code?
Thanks.
JesusFreke
If you don't need a new fusion component or linked component for every item, you can use the TemporaryBRepManager to perform the transformation much more quickly.
e.g. The following ran in about .5s for me
def run(context):
ui = None
try:
brep = adsk.fusion.TemporaryBRepManager.get()
new_occurrence = rootComponent.occurrences.addNewComponent(trans)
vector = Vector3D.create(1, 0, 0)
for body in firstComp.bRepBodies:
new_translation = trans.translation
new_translation.add(vector)
trans.translation = new_translation
body_copy = brep.copy(body)
brep.transform(body_copy, trans)
new_occurrence.component.bRepBodies.add(body_copy)
adsk.doEvents()
print('{:.2f} s'.format(elapsed_time))
except:
print(traceback.format_exc())
You can still create a new component for every item, and add the transformed body to the new component. I tested that out too, and it was still only about 1.5s for me.
Although, note that both of these solutions are creating completely separate bodies+components for every item, while in your original code, you were making new linked occurrences of the same component. So if you do actually need linked occurrences, neither of these will work.
JeromeBriot
Hello @JesusFreke ,
I moved from occurrences.addNewComponent to occurrences.addExistingComponent for efficiency reason when I first wrote this add-in. That was just before the TemporaryBRepManager was added to the API.
Anyway, I did some tests and it does speed up the process.
For one design with 277 electronic component to be placed:
  • occurrences.addExistingComponent only => 13s
  • occurrences.addExistingComponent + transform => 57s
  • TemporaryBRepManager + transform => 45s
For another design with 447 electronic component to be placed:
  • occurrences.addExistingComponent only => 38s
  • occurrences.addExistingComponent + transform => 327s
  • TemporaryBRepManager + transform => 81s
The difference between "occurrences.addExistingComponent only" and "occurrences.addExistingComponent + transform" is that I just comment/uncomment the next line in my code:
So my code is now faster but it's way far from other software I tried. I did tests with FreeCAD 0.18 and DesignSpark Mechanical 4.0 and the import of more than 1000 electonic components takes less than 30 seconds. It can take hours with Fusion 360!
Again, there is a efficiency issue with the transform process. It's fast for less than 100 components but becomes slower and slower when this number increase.
JesusFreke
81s still seems way longer than I would expect. My sample code was able to do all 200 transforms in less than a second. Granted, they were just translations, but it's all just matrix multiplication, so I don't think more "complex" transformations would necessarily be more expensive.
Can you summarize the code you were using for that test?
JeromeBriot
Here is another example that creates 1000 components:
import random
import time
import math
import platform
import os
def run(context):
    ui = None
    try:
        x = [[0,1,1,0,0], [1,2,2,0,0,1,1], [0,2,2,0], [0,1,1,0,0]]
        y = [[0,0,1,1,0], [0,0,2,2,1,1,0], [0,0,1,0], [0,0,1,1,0]]
        h = [0.2, 0.5, 0.1, 0.2]
        numIteration = 1000
        transformTrans = adsk.core.Matrix3D.create()
        transformRot = adsk.core.Matrix3D.create()
        transformFlip = adsk.core.Matrix3D.create()
        vector = adsk.core.Vector3D.create(0.0, 0.0, 0.0)
        vectorY = adsk.core.Vector3D.create(0.0, 1.0, 0.0)
        vectorZ = adsk.core.Vector3D.create(0.0, 0.0, 1.0)
        origin = adsk.core.Point3D.create(0.0, 0.0, 0.0)
        elapsedTime = [0]*numIteration
        for i in range(0, numIteration):
            n = random.randint(0, 3)
            startTime = time.time()
            trans.setToIdentity()
            vector.x = 100*random.random()
            vector.y = 100*random.random()
            vector.z = 0.0
            if random.random() > 0.5:
                transformFlip.setToRotation(math.pi, vectorY, origin)
                trans.transformBy(transformFlip)
            transformRot.setToRotation(random.random()*math.pi, vectorZ, origin)
            trans.transformBy(transformRot)
            transformTrans.translation = vector
            trans.transformBy(transformTrans)
            comp = occ.component
            sketches = comp.sketches
            sketchesPlane = comp.xYConstructionPlane
            for j in range(0, len(x[n])-1):
                lines.addByTwoPoints(adsk.core.Point3D.create(x[n][j], y[n][j], 0), adsk.core.Point3D.create(x[n][j+1], y[n][j+1], 0))
            extrudes = comp.features.extrudeFeatures
            distance = adsk.core.ValueInput.createByReal(h[n])
            elapsedTime[i] = time.time() - startTime
        app.activeViewport.fit()
        adsk.doEvents()
    except:
        if ui:
    exportElapsedTimes(elapsedTime)
def exportElapsedTimes(elapsedTime):
    if platform.system() == 'Windows':
        pathName = os.path.join(os.environ["HOMEPATH"], 'Desktop')
    else:
        pathName = '~/Desktop'
    with open(os.path.join(pathName, 'fusion-360-time.txt'), 'w') as file:
        for et in elapsedTime:
            file.write('{:.3f}\n'.format(et))
Here is the plot of the elapsed time at each iteration:
So the creation of the last components took 10 times more than for the first ones (0.02s vs. 0.2s)
The code takes 90s to finish. I would expect 1000*0.02 = 20s
I attached the result file and the code to plot the data:
import platform
import os
import matplotlib.pyplot as plt
else:
with open(os.path.join(pathName, 'fusion-360-time.txt'), 'r') as file:
    lines = file.readlines()
lines = [x.replace('\n', '') for x in lines]
t = [float(x) for x in lines]
plt.plot(t)
plt.xlabel('Iterations')
plt.ylabel("Time (s)")
Thank you.
