ExtractBOM - Modification
isocam
isocam
Can anybody help?
I need the Python script checking/modifying. Please see:
Solved: Extract BOM - Add Folder To Output - Autodesk Community - Fusion 360
I need the following modification:
The script outputs the part version. For example, part number 12345 gets outputted as 12345 v32
I only need it to output the part number only. Can this be done?
Please also see the bottom of the link as I need to output the folder name only (in this case "BIL Castors).
Many thanks in advance!
Darren
kandennti
Hi @isocam .
I overlooked it.
How about this?
import adsk.core, adsk.fusion, traceback
import re #<-Here
def walkThrough(bom):
def run(context):
    ui = None
                bom.append({
                    'instances': 1,
                    'component': comp,
                    'name': re.split(' v\d+', comp.name)[0], #<-Here
                    'description': comp.description,
                    'folderName': folderName,
