Webshop Order - Import Fusion
Order6QA24
Message 1 of 1
Order6QA24
I would like to know if there is some prebuild possibility to import an order from an webshop into the Fusion program. In the webshop you can build customized tools (by filling in some form fields). The idea is that after ordering a customized tool, the tool gets converted (via API and the correct params) to a file which can get imported in Fusion.
The question is, what would you suggest is the best way to accomplish this conversion?
Thank you in advance.
Best regards
Replies (0)
