Extract BOM - Add Folder To Output
isocam
isocam
Can anybody help?
I have a python script that extracts the BOM from a Fusion 360 assembly.
I need to add the actual folder name where I have inserted a part into the assembly.
For example,
Please see the attached picture.
When the path contains the words "Purchased Parts" then I need to add the folder name to the BOM
(In the case shown in the picture, this will be "BIL Castors")
Also,
How do I save the file to the desktop, rather than showing them is a message box?
I have attached the actual Python script (I have changed .py to .txt)
Many thanks in advance!
Darren
kandennti
Hi @isocam .
How about something like this?
import adsk.core, adsk.fusion, traceback
def walkThrough(bom):
    def spacePadRight(value, length):
        pad = ''
        if type(value) is str:
            paddingLength = length - len(value) + 1
        else:
            paddingLength = length - value + 1
        while paddingLength > 0:
            pad += ' '
            paddingLength -= 1
        return str(value) + pad
    def getInfo(item) -> str:
        return ''.join([
            spacePadRight(item['instances'], 15),
            spacePadRight(item['name'], 25),
            spacePadRight(item['description'], 25),
            spacePadRight(item['folderName'], 15),
    infos = [getInfo(item) for item in bom]
    return '\n'.join(infos)
def hasTargetFolder(
    targetName: str,
    doc: adsk.fusion.FusionDocument) -> bool:
    df: adsk.core.DataFolder = doc.dataFile.parentFolder
    folderNames = []
    while True:
        if df.isRoot:
            break
        if not df.parentFolder:
            break
        folderNames.append(df.name)
        df = df.parentFolder
    if targetName in folderNames:
        return True
    return False
def writeFile_Desktop(filename, txt):
    import os
    desktop_dir = os.path.expanduser('~/Desktop')
    import pathlib
    path = pathlib.Path(desktop_dir, filename)
    with open(path, mode='w') as f:
        f.write(txt)
def run(context):
    ui = None
    targetFolderName = 'PurchasedParts'
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        title = 'Extract BOM'
        if not design:
            ui.messageBox('No active design', title)
            return
        root = design.rootComponent
        occs = root.allOccurrences
        bom = []
        for occ in occs:
            comp = occ.component
            jj = 0
            for bomI in bom:
                if bomI['component'] == comp:
                    bomI['instances'] += 1
                    break
                jj += 1
            if jj == len(bom):
                bodies = comp.bRepBodies
                doc = comp.parentDesign.parentDocument
                if hasTargetFolder(targetFolderName, doc):
                    folderName = targetFolderName
                else:
                    folderName = ''
                bom.append({
                    'instances': 1,
                    'component': comp,
                    'name': comp.name,
                    'description': comp.description,
                    'folderName': folderName,
        msg = walkThrough(bom)
        writeFile_Desktop(f'{root.name}.txt', msg)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
isocam
Can anybody help?
When I run the script, the part version gets added to the output.
For example,
1000-001 v123
Is there any way to remove the version number (eg v123)?
Also,
I have a folder called "Purchased Parts" with a sub-folder Called "BIL Castors".
The output is only showing "Purchased Parts" rather than "BIL Castors".
Is there any way of modifying the code to output the sub-folder, in this case it would be "BIL Castors"?
Many thanks in advance!!!
Darren
