Coordinate algebraic sign (-) in point geometry print command
_fabschke_
_fabschke_
I am trying to print (and later export to a csv file) the pnt coordinates of 2+ sketch or construction points.
But the issue I am having currently is, that some coordinates should have a "-" before the value.
import adsk.core, adsk.fusion, adsk.cam, traceback, csv
app = adsk.core.Application.get()
ui = app.userInterface
# Initialize variables
i=0
coord= []
templist = ()
#1
pntEntity = ui.selectEntity('Select a sketch point', 'SketchPoints')
pnt = adsk.fusion.SketchPoint.cast(pntEntity.entity)
templist = ('{}'.format(pnt.geometry.z), '{}'.format(pnt.geometry.y), '{}'.format(pnt.geometry.x))
coord.append(templist)
print(templist)
templist = 0
print(coord)
#2
#print(templist)
templist = 0
print(coord)
The output should be:
[('0.0', '0.3000234521308176', '-2.3838218031176135'), ('0.0', '3.0992720830223104', '-5.589760148808029')]
but it is:
[('0.0', '0.3000234521308176', '2.3838218031176135'), ('0.0', '3.0992720830223104', '5.589760148808029')]
so basicely without the "-".
In Fusion i get the - shown if i select the point
Thank you guys in advance
JeromeBriot
Do you want to export the coordinates in the sketch space or in the world space?
SketchPoints have two different properties : geometry and worldGeometry
_fabschke_
The world space I think.
What excactely is the difference?
JeromeBriot
The sketch space is the 2D space where you draw the sketch (i.e. the z coordinate is always 0.0)
The world space is the 3D space of Fusion 360 represented by the viewcube at the top-right corner of the UI.
_fabschke_
Ok, got it.
It would be good to get the World geometry.
I am currently no sure I nedd the Z_coordinate, but in case i do not need the z-coordinate i can always set it to zero afterwards.
