C-Axis mill/turn trouble on Mazak (EIA)
Oliver_Lidstrom01
Message 1 of 13
Oliver_Lidstrom01
Im new to mill/turn and i just started with Mazak MSY250, i have a problem when it comes over 360 degrees and starts over again on 0 instead of keep going it switches direction and mill away everything it comes over.
Is it an option in fusion so it keeps going over 360? Or is it something in the machine im missing?mazak1.jpgmazak2.jpg
Replies (12)
Message 2 of 13
Joshua.mursic
This seems like a problem with your post processor. What does you machine configuration look like in your post?
Message 3 of 13
Oliver_Lidstrom01
Yea maybe it is, because it also puts out M901 and it doesnt read it, and also G53.5, i have to change this to G53 by hand.
Do you mean like this?
Message 4 of 13
Joshua.mursic
The Mazak Quick Turn 250-MS post processor probably needs to be modified.
Inside the post try looking for a line of code that reads like this:
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:true, preference:0});
the cyclic argument means that the axis can rotate indefinitely. If that argument is a range instead, then the C axis will rotate to 360 and then turn back to 0 to start the rotation.
If you would like you can attach the Mazak Quick Turn 250-MS.cps file and I can take a quick look
Message 5 of 13
Oliver_Lidstrom01
@Joshua.mursic, Thank you, im sorry for bad picture but it is the MSY post processor i use, i will take a look myself to but here you have the file
Message 6 of 13
Joshua.mursic
Can you send me a screenshot of your CAM setup? I want to see what kind of operations you are using
Message 7 of 13
Oliver_Lidstrom01
Message 8 of 13
Joshua.mursic
Okay, sorry for all the back and forth. If possible please attach the fusion project, then I can test and see where exactly the issue is coming from
Message 9 of 13
Oliver_Lidstrom01
It looks like i cant just share the link, do you know if there is any other way so you can see the operations?
Message 10 of 13
Joshua.mursic
Yea export the project as f3d and send it here
Message 11 of 13
Oliver_Lidstrom01
Message 12 of 13
Joshua.mursic
Hey @Oliver_Lidstrom01 , I tried to find the issue but I was unable to. This definitely seems like an issue with the post processor itself but I am not experienced enough to find the problem. Good luck.
Message 13 of 13
Oliver_Lidstrom01
Okey, thanks for the help anyways, i will try to find out a solution to this problem
