_ui.messageBox problem
brad.bylls
brad.bylls
Trying to show message box.
I get this:
What am I missing?
Thank you.
Brad Bylls
BrianEkins
I don't see any problems. I typed the following three lines into the TEXT COMMAND window with the "Py" option selected and when I run the last line, I get the expected dialog.
app = adsk.core.Application.get()
ui = app.userInterface
answer = ui.messageBox('Check your inputs,\nScrew is shorter than clearance length!')
Brian Ekins
Jorge_Jaramillo
How are you running the script?
Could you share the script?
brad.bylls
Attached is the file.
Brad Bylls
Jorge_Jaramillo
Hi @brad.bylls ,
I don't see the run method in your source file.
I can see in your source code you have CreateInchFHSCS class and drawBolt method.
How are you calling those?
Are you running the script from Fusion360?
brad.bylls
It runs through a framework that Patrick Rainsberry created.
Brad Bylls
