[Bug] Wrong translation of plane using plane.transform in base feature
JeromeBriot
Mentor Mentor
JeromeBriot
I think that this bug is the same as the one reported 5 years ago in this discussion: Creating sketch from baseFeature - aka not parametric - fail to update transform
The following code try to translate a plane according to a direction:
  • If direction is set to X => translation of the plane YZ
  • If direction is set to Y => translation of the plane XZ
  • If direction is set to Z => translation of the plane XY
But if direction is set to 'X' or 'Y', the translation of the plane is incorrect.
  • For 'X', instead of translating the YZ plane in the X direction, it translates the XY plane in the X direction
  • For 'Y', instead of translating the XZ plane in the Y direction, it translates the XY plane in the Y direction
import adsk.core, adsk.fusion, traceback
def run(context):
    try:
        direction = 'X'
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComponent = design.rootComponent
        baseFeats = rootComponent.features.baseFeatures
        baseFeat = baseFeats.add()
        baseFeat.startEdit()
        planes = rootComponent.constructionPlanes
        planeInput = planes.createInput()
        planeInput.targetBaseOrFormFeature = baseFeat
        offset = adsk.core.ValueInput.createByReal(0.0)
        if direction.lower() == 'x':
            refPlane = rootComponent.yZConstructionPlane
        elif direction.lower() == 'y':
            refPlane = rootComponent.xZConstructionPlane
        elif direction.lower() == 'z':
            refPlane = rootComponent.xYConstructionPlane
        planeInput.setByOffset(refPlane, offset)
        plane = planes.add(planeInput)
        transform = adsk.core.Matrix3D.create()
        vector = adsk.core.Vector3D.create(0.0, 0.0, 0.0)
            vector.x = 10
            vector.y = 10
            vector.z = 10
        transform.translation = vector
        plane.transform = transform
        baseFeat.finishEdit()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
 Thank you
kandennti
Hi @JeromeBriot .
The "transform" works correctly if you get it from plane.transform instead of Matrix3D.create method.
        # transform = adsk.core.Matrix3D.create()
        transform = plane.transform # <- here
            vector.x = 10
JeromeBriot
Thank you @kandennti
Your workaround works perfectly. Bravo ! 👏
 The bug still exists. Or at least a lack of information in the documentation. @BrianEkins : any ideas ?
BrianEkins
This was a good question and caused me to learn something.
You can think of a construction plane as a coordinate system.  The face of the plane is its X-Y plane and Z is normal to the plane. The transform returned by the plane's transform property is defining the current position and orientation of the plane.  Setting this property redefines the transform.
If you create a new construction plane parallel to the root Y-Z plane and a zero offset, it is the special case where its current position and orientation are defined by an identity matrix.  A plane on the Y-Z has a transformation matrix like this:
0.0 0.0 1.0 0.0
1.0 0.0 0.0 0.0
0.0 1.0 0.0 0.0
0.0 0.0 0.0 1.0
You can see it's X direction is in (0, 1, 0), it's Y direction is in (0, 0, 1), it's Z direction is in (1, 0, 0), and it's translation is zero.
In the initial sample, code it's starting with an identity matrix, which is what's created when you create a new Matrix3D object, and then it's setting the translation part of the matrix. This has the effect of reorienting any plane to lie on the model X-Y plane.  To do what you were originally doing, you need to get the original transform and then apply the desired translation.  For this to work in a general case where there might already be some translation to the plane you would do something like this to translate it 5 cm in the X direction:
# Define the transform to apply.
transMatrix = adsk.core.Matrix3D.create()
transMatrix.translation = adsk.core.Vector3D.create(5.0, 0.0, 0.0)
# Get the current transform that defines the plane's position and orientation.
planeTransform = constPlane.transform
# Multiply the current transform with the desired change.
planeTransform.transformBy(transMatrix)
# Apply the new transform to the plane.
constPlane.transform = planeTransform
Brian Ekins
JeromeBriot
Thank you @BrianEkins. It's cristal clear now.
