Find Folder Name Using Wildcard
isocam
isocam
Can anybody help?
I have a number of sub-folders in a main folder thus....
C:\Users\Public Documents\Drawing Files\
1000 - Thrust Bearing Assembly
1010 - Mixer Shaft Assembly
1020 - Mixer Platform Fabrication
1030 - Mixer Loading Hopper Fabrication
Using a wildcard, how can I show the full folder name using a Python script.
For example, using the wildcard "1020", the message box should show "1020 - Mixer Platform Fabrication"
Many thanks in advance!!!
IsoCAM
BrianEkins
The API doesn't do any wildcard searches but you can loop through all of the folders and check to see if each of the names matches you search string in any way you want.
In your specific example, you could use the string function startswith like:
if folderName.startswith('1020'):
    app.log(folderName)
For a more general wild card search look at the python function fnmatch as discussed here in StackOverflow.
Brian Ekins
