Add in conversion option to properties dialog
terry_fusion
terry_fusion
I've been doing a bit of work in creating specific sized volumes for a defined space and find that I'm taking the volume information from the property dialog box and then going to google to find a conversion table.
I'm not a programmer, so I have to ask.
Would there be an easy way to add into the dialog box a drop down menu that list a number of different types of volume conversions?  Gallon, Liter, Milliliter, etc that could be converted to the added to the results in the dialog box?
Maybe even add one for mass?
Just an idea.
kandennti
Hi @terry_fusion -San.
I don't think it is possible to customize the properties dialog.
Instead, I have created a script that displays the volume of the selected solid body in multiple units.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_Multi_Units_Volume',
    'name': 'Multi Units Volume',
    'tooltip': 'Multi Units Volume'
_bodyIpt: core.SelectionCommandInput = None
_txtIpt: core.TextBoxCommandInput = None
UNITS_LIST = [
    "mm^3",
    "cm^3",
    "ml",
    "l",
    "gal",
    "qt",
    "pt",
    "cup",
    "fl_oz",
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            cmd.isOKButtonVisible = False
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            global _bodyIpt
            _bodyIpt = inputs.addSelectionInput(
                "_bodyIptId",
                "SolidBody",
                "Select Solid Body",
            _bodyIpt.addSelectionFilter(core.SelectionCommandInput.SolidBodies)
            global _txtIpt
            _txtIpt = inputs.addTextBoxCommandInput(
                '_txtIptId',
                'Volume',
                len(UNITS_LIST)-1,
                True
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.InputChangedEventArgs):
        global _bodyIpt
        if args.input != _bodyIpt: return
        global _txtIpt
        if _bodyIpt.selectionCount < 1:
            _txtIpt.text = "-"
            return
        body: fusion.BRepBody = _bodyIpt.selection(0).entity
        volume = body.volume # cm^3
        print(volume)
        app: core.Application = core.Application.get()
        des: fusion.Design = app.activeProduct
        unitsMgr: core.UnitsManager = des.unitsManager
        msgLst = [unitsMgr.formatInternalValue(volume, u, True) for u in UNITS_LIST]
        _txtIpt.text = "\n".join(msgLst)
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
terry_fusion
That is very much appreciated, thank you for taking the time to do this.
I felt it was something that could be done, just wasn't sure how.
Thanks again! 🙂
terry_fusion
I've been using this script a lot lately and its been a wonderful boon to my workflow.
One more question, is there a way I can add in an icon on the toolbar or menu? say under the inspect menu?
Thanks again for the help.
kandennti
@terry_fusion -San.
To add an icon to the menu, it must be an add-in, not a script.
We will create an add-in later.
kandennti
@terry_fusion -San.
The add-in has been created and is attached.
When you run the add-in, the command is added to the bottom of the inspect panel.
terry_fusion
I am appreciative,  that was so kind of you to do that.
I feel it will be a feature I use often.
Regards.
