startLocalRender on OSX
charliex2
Message 1 of 10
charliex2
I have this snipped of code in a plugin, the document is saved, doesn't matter the contents. A simple sphere at 0,0,0 shows the issue
r->progress() always returns 0 no matter how long i wait.
identical code works just fine on windows, what am i doing wrong?
is there any sort of global error/checking state i can look at it, nothing comes out on the console, normally it seems if the render can't/won't start it'll fail the startLocalRender call, but this passes.
latest version of fusion on all.
OSX 14/XCode 15 beta 6, macbook pro m2 max, i know its a beta/beta combo but i can go check it on a different machine on 13 or earlier as well but i figured i'd check if there was anything obvious i missed.
thanks!
app is initialised ok, and this is in run, the code does work on windows
// Get the active design.
Ptr<Design> design = app->activeProduct();
if (!design)
return false;
double propertyValue;
Ptr<RenderManager> renderManager_var = design->renderManager();
if (!renderManager_var)
return false;
Ptr<Rendering> rendering_var = renderManager_var->rendering();
if (!rendering_var)
return false;
// set the rendering properties
rendering_var->resolutionWidth(1000);
rendering_var->resolutionHeight(1000);
rendering_var->renderQuality(100);
auto r = rendering_var->startLocalRender();
if ( r ) {
auto propertyValue = r->progress();
Replies (9)
Message 2 of 10
john.kirchner
Have you tried your MacBook making a local render in F360 using the normal UI workflow? That's fine if you use Standard(50) quality, curious if that renders ok.
Message 3 of 10
charliex2
hiya,
using the ui to local render works as expected.
i just don't get any progress when using the api , it is always zero, from the future not sure if its actually rendering
setting renderQuality(50) same results, 0 progress
Message 4 of 10
john.kirchner
Ignoring the progress value being returned - when using API will the render ever reach 'FinishedLocalRenderState (2)' when you grab renderState?
Message 5 of 10
charliex2
oops accidentally clicked accept solution there, it does return ProcessingLocalRenderState , running a quick test to see if it changes state.
Message 6 of 10
charliex2
it stays in QueuedLocalRenderState,  i let it sit for a long time and it never started, xcode showed the wrong enum, but i single stepped a  few times and it never changed, which seems to make more sense given the progress never changes.
Message 7 of 10
charliex2
i tried it from Python (which i knocked up this little test script just to see if it was different) same results on OSX vs Windows, the script isn't bullet proof obviously but it shows the same issue..
OSX , progress is 0, then the future disappears and the render is gone. i know the test for the future in the script isn't complete but it happens almost immediately sometimes (And the c++ version does handle the future differently), but never gets to render state 2
Windows, progress repeats as expected, renderstart popup in the UI is 2
#Author-
#Description-
import time, adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        renderManager = design.renderManager
        rendering = renderManager.rendering
        rendering.renderQuality = 100
        rendering.resolutionWidth = 1000
        rendering.resolutionHeight = 1000
        renderFuture_var = rendering.startLocalRender()
        renderState = renderFuture_var.renderState
        #ui.messageBox('Render State:\n{}'.format( renderState ))
        # wait until the render state is not 1
        while renderState == 1:
            # sleep for 100 milliseconds
            time.sleep(0.1)
            if renderFuture_var.isValid:
                progress = renderFuture_var.progress
            print(progress)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Message 8 of 10
charliex2
just to remove any beta software/arm hardware etc, i tried it one my older macs, which is all mainline
Message 9 of 10
john.kirchner
Thank you for taking the time for testing this out. One of our engineers was also able to reproduce this on their Mac machine, I've logged a bug ticket for further investigation.
Message 10 of 10
charliex2
great, thanks john!
