Fusion Support
Flush Trim Router Type Shaping
1 REPLY 1
ashton2AV59
135 Views, 1 Reply
Is there a way to do something similar to a flush-trim router on this blue material, making it flush with the grey material by removing mass from the blue material?
Labels (1)
1 REPLY 1
sutherland-
in reply to: ashton2AV59
Hi @ashton2AV59
Do you need any offset from the gray material to the blue material? Or you want it to be 1 to 1 flush?
If you want it to be 1 to 1 flush then you can use "Combine" feature with the "Intersect" option.
As the target body set the blue material and check "keep tools". See GIF below:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Technology Administrators
