Is there a way to do something similar to a flush-trim router on this blue material, making it flush with the grey material by removing mass from the blue material?
Solved by sutherland-. Go to Solution.
Hi @ashton2AV59
Do you need any offset from the gray material to the blue material? Or you want it to be 1 to 1 flush?
If you want it to be 1 to 1 flush then you can use "Combine" feature with the "Intersect" option.
As the target body set the blue material and check "keep tools". See GIF below:
