I'm not seeing that error in your file, and posting the code out doesn't yield any errors either 🤔
The first generation after selecting the 2D contour function does not show an error. But when I choose "generate" again in the tree Shows the error as described above. This message also appears when I want to generate a path. The message from the photo in the attachment shows "too large tool radius in line 90"
On the first page I managed to skip a few lines of code that slightly changes the outline. There were a lot of lines traveling by ~ 0.006mm. I thought that when I generate the program from the other side it will be similar but it is not. The differences in contour are getting too big. There is a problem here as in the picture in the attachment.
I am seeing the same issue when I am generating gcode for a (modified) Autodesk XYZ mill which I am using to control a CNC router. If I ignore the warning and post process anyway, I get working gcode - but it just seems that this is not a warning that makes a lot of sense.
You can turn that warning off in Preferences:
It may seem nonsensical to you, but your opinion might change if you had a toolpath that took 45 minutes to calculate 😉
