Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Valid tool path milling
8 REPLIES 8
Message 1 of 9
512 Views, 8 Replies
Hello!
(Text translated google translate.)
I have a problem generating a program for a heidenhain milling machine.
I have a model in a dwg file. Thanks to Fusion360 I created a 3D model.
I want to create the outer contour of the body that is offset by 1mm and I want tool compensation in the milling machine.
And there is a problem because when it generates the program, the error message appears: "Generate Toolpath The selected orientation has a valid toolpath. Do you want to generate the operation anyway?"
Could this be a problem with the drawing?
Can you help me find what I'm doing wrong? Or how to do it correctly.
File in attachment.
Thank you and best regards Rafał.
Labels (1)
8 REPLIES 8
Message 2 of 9
seth.madore
I'm not seeing that error in your file, and posting the code out doesn't yield any errors either 🤔
Seth Madore
Message 3 of 9
in reply to: seth.madore
The first generation after selecting the 2D contour function does not show an error. But when I choose "generate" again in the tree Shows the error as described above. This message also appears when I want to generate a path. The message from the photo in the attachment shows
"too large tool radius in line 90"
On the first page I managed to skip a few lines of code that slightly changes the outline. There were a lot of lines traveling by ~ 0.006mm. I thought that when I generate the program from the other side it will be similar but it is not. The differences in contour are getting too big. There is a problem here as in the picture in the attachment.
Message 4 of 9
Error foto
Message 5 of 9
seth.madore
Which Heidenhein version are you using?
Seth Madore
Message 6 of 9
AVIA VMC 800 HEIDENHAIN I510
Message 7 of 9
I530 2017year
Message 8 of 9
mark9XJEG
I am seeing the same issue when I am generating gcode for a (modified) Autodesk XYZ mill which I am using to control a CNC router.    If I ignore the warning and post process anyway, I get working gcode - but it just seems that this is not a warning that makes a lot of sense.
Message 9 of 9
seth.madore
You can turn that warning off in Preferences:
It may seem nonsensical to you, but your opinion might change if you had a toolpath that took 45 minutes to calculate 😉
Seth Madore
