Change Fusion 360 symmetric extrusion option by distance to be the total extrustion distance rather than half. In Autodesk Inventor if you want to extrude a sketch symmetrically about the sketch plan you enter the total extrustion distance not half of it. Fusion 360 forces you to either type a mathmatical distance or figure it in your head. Cut out the extra step.
Example: I sketch a rectangle and I want to extrude it symmetrically about the sketch plan by 40mm. I should be able to type in 40mm in the distance field not have to divide by two to get 20mm on each side. Pretty easy here but to do one that is a total of 411/64" distance, I have to type extra characters in the distance field to do the math because I am not that fast on doing this in my head.
The two applications should match anyway!
