rotating pin-slot joint
There is no way to create a pin-slot joint that also rotates other than by making contact sets which is problematic because they tend to break apart especially when producing motion studies. Please vote for implementing a rotating pin-slot joint - you never know when you might need one...
3 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
lure23
@Peter_Stoneham I've been looking at similar suggestions over the years (2016-19), but not quite sure what you were asking here.
If you still miss the feature, have a look at Curved Slider Joint and maybe we can discuss this one-one-one. I'm trying to aggregate votes to that one, since it seems that having N almost identical entries only serves to dilute the overall vote (which matters to Autodesk as Keqing mentions).
(I know the entry is archived.=)
