Reverse Animate Model option
I think there should be a option of reverse animate model . as we click on animate model , the model will rotate in direction where the flag is facing in clockwise or anticlockwise . If the model is animating in clockwise direction , Some time we need the model to rotate in anti direction . But there is no option for it . So for that I delete the joint and keep the flag in antidirection , to get the anti direction . So , i think there should also an reverse animate model option .
3 Comments
Yes it is needed, sometimes i am also stucked in it.
Yeah and a way to control the speed of animate model/joint would be nice too. I made an engine and when I told the crankshaft to rotate and spin the revolute joint it spun too fast and parts glitched out and it created a lot of problems.
The only trick I have for you is to view your model from the opposite side and it will sort of mirror the rotation or motion. I know that won't always work but it does a lot of the time if you want to see things work in the reverse order.
