Easy object transparency control
I know this as already been discussed, like there :
http://forums.autodesk.com/t5/design-and-documentation/transparency-of-bodies-when-designing/td-p/52...
But the provided solution is not simple at all.
On complex models you have objects getting in your way. You can hide them easily (bulb in the browser) but not making them semi transparent. Modifiing the appearence is ok but when you want to to this 50 times a day it's quite a hassle to get back in appearence each time we want to change this. And we need to be able to see through some pieces with the geometry of other peices.
It woud be easier to have an item in the browser menu (under show/hide) and a submenu with default values to select: 10% to 90% by increments of 10 % would be far than enough i think.
It coud be also be in the right click ring on a body (wich is under exploited in my opinion)...
Thx autodesk team...
9 Comments
Oceanconcepts
This seems like a simpler way to access the current opacity control function. Activating a component does ghost the other components, but sometimes that may not be what is desired- I may want a couple of components at full opacity, the rest transparent. I like this approach in that it is more direct and controllable.
Yes, very good idea.
I'm surprised it's not (yet) in Fusion 360.
I use it a lot in Rhino/T-Splines and it's very usefull tool.
haughec
This is a great idea.  I've logged FUS-22795 to track this internally.
Charles
haughec
Status changed to: オートデスク今後検討
promm
Status changed to: RUG-jp審査通過
promm
Status changed to: オートデスク審査落選
keqingsong
Good news! This is coming in our May 25 update!
keqingsong
odolyte
Thanks a lot Keqing ! This is awesome...
