Diameter dimension on a circular pattern
My request its very simple, I would like to have the ability to create a diameter dimension on a circular pattern, where you pick the center of the main circle first and the diameter of any circle on the circular pattern, thanks.
6 Comments
mikeireland
If this request is similar to the need to dimension something like a bolt hole circle or clearance circles, I am in agreement. We can use such a feature.
rafaelq1d1
Yes, that's the idea!
yanouk73
Hi, this is not just an idea, it's a must!
when you do circular pattern of 36 holes in a plate, and you use an indexing plate to machine it, you need a screw diameter and angle quotation type
TimeraAutodesk
Status changed to: オートデスク審査落選
yanouk73
It need to make a center line that is a circle, and each hole of the pattern should have a short center line straight that intersect with the center of the patern rotation point.
on the center line circle, we can put the diameter, maybe the diameter can be added automaticly when you create the center circle line, it's allwas faster to erase something created automaticly then creat it when it's not done, but this is just an idea.
This applies to bolts and holes too - who drills a radius?
