Varying Pattern Spacing
I would like to have the option in all patterns to vary the spacing between instances.  So if you have a linear pattern and the spacing between the instances are 1mm, I want an option to increase the spacing of each instance by a set ammount.
If I would increase the spacing by 1mm then I would want the pattern to have a first space of 1mm, then the second would have a space of 2mm, then the third would have a spacing of 3mm, and so on.
The only option to do this right now is to create an equation where the spacing is a variable.  Then each space dimension is tied to an equation that is referencing the spacing.  This works ok for model changes but takes a very long time to set up.  Having the software do it automatically would save a lot of time.
1 Comment
keqingsong
