Finish Pass Overlap on all toolpaths that could use them
I'd love to see Finish pass overlap make its way to tools like horizontal and bore. When using both of these tools I am usually left with a little bit of stock left over at the entrance and exit of these tool paths.  While I realize they reside in completely different kernals, I am constantly having to add additional contours with overlap to finish these strategies.  Even using multi pass/multi finish in Bore still leaves the little bump of extra material from tool flex.  Adding Overlap would let a user just use one of the tool paths, instead of adding in a seperate 2D contour finish.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
