Construction History / Design Tree
It was mentioned in the old forum, so I post it here again:
Currently when I create geometry from sketches and edit the sketches afterwards the changes are not applied to the geometry as well.
This prevents me from using Fusion360 as a conceptual modeler where I explore design ideas and styling through out the modeling process.
UI.png Image:
Currently you can see the new body that is created, with the two extrusions I used, a cube and cylinder.
In an ideal situation I can click on the cylinder extrusion feature and edit then hight and radious of the cylinder.
Currently I have to go into the move face mode, which works somewhat. But in the image I can only select the bottom cap of the cylinder not the top cap which is outside the cube volume.
Error.jpg:
Also what Fusion360 is doing with the cylinder volume is not making sense. In the following picture you can see that I can move the cylinder to the edge and thus recut the cube. Thats fine, however it seems I cannot bring the cylinder back into the cube center.
2 Comments
schneik-adsk
Status changed to: オートデスク審査落選
schneik-adsk
