Variable Edge rounding
It seems that currently when you select edges to round you cannot add custom values for different edges and also custom values along a certain edge like a wider radius at the midpoint, a smaller radius at the end of the edge.
Would be nide to have this.
7 Comments
Adding variable fillet will be great. I usually work on Model mode for parts that need accurate parametric dimensioning and there's simply no option to add a variable fillet to the model. In fact, this is one of the argument point against migrating to Fusion 360 from Rhino.
schneik-adsk
Status changed to: オートデスク審査落選
We have multiple improvments comming for fillets. Variable fillet, chordal fillet and G2 fillets are high on the list? Would you agree?
cekuhnen
Currently it looks that the edge rounding is rather basic allowing only one value input.
Adding different values along an edge selection is really a must for product design.
schneik-adsk
Status changed to: 実装予定
cekuhnen
Yes they are a must have!
Just basic one radius fillets will incredibly cripple the usability scope.
schneik-adsk
schneik-adsk
