Trying to draft this saw blade part but can't figure out how to draw the last angle. Any help would be appreciated.
Solved by etfrench. Go to Solution.
Are you still working on this?
I always look to the manufacturing process used to create the feature out on the shop floor.
I am assuming a revolving end mill or chamfer cutter at an angle - plunged into the part and then translated out the slot. Revolve and Sweep of the cutter (we can often cheat in CAD with only a Sweep).
Do you have a picture of your process setup?
You can back up a step in the Timeline prior to Pattern.
Add the necessary feature(s) and then edit the Pattern to include the added feature(s).
Post back if you haven't figured it out.
BTW - if you are running Fusion on a Windows OS you can use the Windows commands Shift Win S (screencapture) and Ctrl v (Paste) to include images in your posts.
Could you upload that file so I can see how you did that? I'm having trouble duplicating it.
Could you upload this file? I'm having trouble duplicating what you did.
Sorry double post.
Yes still working on it when I can. Having trouble with the angles.
My first thought was to make a endmill on that angle and plunge it in then pulling it around to achieve to proper cut, but I could always use a ball nose to make this too just depends on time.
