Rotating Materials?
Rotating Materials?
mail8YLTP
Message 1 of 10
Rotating Materials?
mail8YLTP
Is there a simple way I can rotate this appearance mapped pine material so the grain is running longitudinally?
Replies (9)
Message 2 of 10
jhackney1972
When you are asking questions like this, always supply your model so the Forum users can show the process on your model.  The video will explain two ways to do this change.  I prefer the first method.
(view in My Videos)
John Hackney, Retired
Message 3 of 10
mail8YLTP
Perfect thank you. I will attach my model in future,,,
Message 4 of 10
jason6JL4J
I know this is an older post, but it appears that rotating the appearance completely removes the wood look and just turns the grain into lines. The left image is the appearance at default, the right image is rotated. I suppose it still gets the point across, but would really like to have it still look like wood grain if possible.
Message 5 of 10
TheCADWhisperer
@jason6JL4J
Message 6 of 10
jason6JL4J
Hello there. File is attached. It's a configured model, but I just exported the active config (same one shown in screenshots)
Message 7 of 10
jhackney1972
Texture Map Controls seems to work well.  Model is attached.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
Message 8 of 10
jason6JL4J
I see you used box. I was using planar. Worked perfectly? Thanks!
Message 9 of 10
jason6JL4J
Not seeing the Accept Solution button
Message 10 of 10
jhackney1972
You must be logged in to see the Accept Solution box.  No problem, I select it for you.
