Is there a simple way I can rotate this appearance mapped pine material so the grain is running longitudinally?
Solved by jhackney1972. Go to Solution.
When you are asking questions like this, always supply your model so the Forum users can show the process on your model. The video will explain two ways to do this change. I prefer the first method.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
