I have a cube and created a half sphere on one side, now I want to have the same sphere on the same location on other side of cube and I don't want to measure and create all over again on other side, but just copy or pull a shape on the other side. I tried many things but didn't find solution. How to do that?
Solved by TheCADWhisperer. Go to Solution.
Thank you.
I tried that but it doesn't work, I get error
iside of this object is a small square and I need to make exact the same on mirror side.
Sketch1 is not fully defined?
Blue lines should keep you awake at night.
Sketches 2 and 3 are not fully defined.
I will have to start over - back in a few minutes...
What is the purpose of Extrude2? Why not edit Extrude1 instead?
Your Sketch1.
My Sketch1
Your Sketch2...
My Sketch2.
Your Sketch3...
My Sketch3.
@damjanRBUXA wrote:don't know what you mean not fully defined and why is that?
https://www.youtube.com/watch?v=lS6PranD8Js
