Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to put a door in to frame? (put body flush against another body)
3 REPLIES 3
jamesliu87878
253 Views, 3 Replies
How can I put a door inside a frame? The two pieces are meant to fit together perfectly, but I can't align it with the move command.
The door (the one with crossbeams) fits in to the side of the main body. Is there a command for this?
Design attached
https://a360.co/32NBadA
3 REPLIES 3
g-andresen
in reply to: jamesliu87878
Please allow Download.
or
File > save as f3d on local drive > attach to next post
günther
davebYYPCU
In a previous thread you needed the doors cut from the frame,
roll the time line back, to before the move, or
if you are using Components, use Joint to put them in place.
Might help.....
g-andresen
This is how easy it is with a joint.
günther
Technology Administrators
